Hello, i am in the process of building a small wind turbine using an 240/415v induction motor to grid tie. I understand i can grid tie phase to neutral and polyphase the other 2, what i am pondering is using 2 phases with a power resistor in series to drop the excess voltage, this would then enable me to switch the windings to delta (with also a series power resistor) at higher wind speeds. Can anybody advise if this would become problematic.
many thanks
many thanks
