Series-pass voltage regulator
Discussion in 'Homework Help' started by notoriusjt2, Dec 15, 2010.
  1. notoriusjt2
    Feb 4, 2010
    209
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    The key elements are the zener diode voltage and the values of R2 & R3.
    R2 & R3 form a voltage divider across the output. The LM741 op-amp will attempt to control the output such that the R2 + R3 divider output voltage fed back to the LM741 negative input is the same as the zener voltage.
  3. notoriusjt2
    Feb 4, 2010
    209
    ahhhh i see
    Vout/Vin = R3/(R2+R3)
    Vin=10V
  4. Ron H
    Apr 14, 2005
    7,050
    657
    That makes no sense when looking at your schematic.:confused:
  5. notoriusjt2
    Feb 4, 2010
    209
    sorry i was reading that formula off my paper where I had it translated for R1 and R2
    it should be
  6. Ron H
    Apr 14, 2005
    7,050
    657
    You came up with Vin=10V. Which node is Vin?
  7. notoriusjt2
    Feb 4, 2010
    209
    i guess you could call it the top of R2.
    between R2 and R3 is 5.6V
    the bottom of R3 is GND
    is this not correct?
  8. Ron H
    Apr 14, 2005
    7,050
    657
    I think you have figured it out. I just thought it would make more sense if you called the junction of R2 and R3 Vin, and the top of R2 Vout, since that's how it's labeled on the schematic.
    If you do that, Vout/Vin=(R2+R3)/R3.
    If you want to communicate using schematics, it is helpful if you stick to the labeling and reference designators on the schematic.
