series parallel RL
Discussion in 'Homework Help' started by laurence rooney, Aug 20, 2011.
  1. laurence rooney
    Aug 18, 2011
    Hi
    This is my attempt at the problem. My answer is close to the book which is
    VR1 = 7.92V & VR2 & L1 = 20.84V. I don't really know if I am going about it in the right way. Can anyone advise.
    p.s. The last line was lost.
    VR2 & L1 = IT * Z
    VR2 & L1 = 35.89m * 581.39
    VR2 & L1 = 20.87V
    Loz
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Rather than start another thread on the same topic, it's best if you simply re-post in the same thread as your original. Then there's no confusion about where you are in the process.
    The error in the analysis you gave was that you should have reduced the parallel branch to its equivalent complex impedance. You then add this complex impedance to the 220Ω to give the total complex impedance.
    From there you can then deduce the current and voltage drops.
