series parallel protection
Discussion in 'The Projects Forum' started by manuel09, Jan 24, 2010.
  1. manuel09
    Aug 29, 2009
    15
    Hello
    My circuit 6led series 800mA x 3parallel (1A max P4 Seoul) PSU:constant current 24Vdc 2.5A. To each series add R2.2ohm seemed very big, any other idea? http://led.linear1.org/led.wiz
    Please help if I want a circuit for over current protection ?
    thank you
  2. 3ldon
    Jan 9, 2010
    82
    does not compute...
    2.2 sounds right but you didn't specify the forward voltage drop of the LED, so it is rather hard to double check it.
  3. manuel09
    Aug 29, 2009
    15
    Yes sorry not remmember 3.2V~4V Vf(forward Voltage) 1A max P4 Seoul 1A max,
    My plan 3.65V 800mA , constant current driver : 24Vdc 2.5A
