Series-Parallel circuits
Discussion in 'Homework Help' started by DCwannabewiz, Oct 25, 2011.
  1. DCwannabewiz
    Oct 25, 2011
    I am having trouble spotting parallel and series circuits when they are drawn above, in between and below each other. Is there an easy way to recognizing them. When they are combined.
    Also I have a problem question.
    R1 in parallel with a branch containing r2 in series with a parallel combination of four other resistors. How would some one visualize and draw this series-parallel combination?
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
    It really boils down to practice alone, when it comes to recognizing parallel and series combinations.
    I 'll rephrase your question to make it a bit more clear:
    (R1) in parallel with ( [...] (r2) in series with (a parallel combination of four other resistors) )
    Can you draw it now?
  3. Jon Wilder
    Oct 25, 2011
    23
    Here ya go -
  4. Georacer
    Nov 25, 2009
    5,151
    1,266
    This thread is moved to Homework Help section now, were "you show me first" rule applies.
    @Jon Wilder
    In the future, keep in mind that in AAC we try to help the students find the answers themselves, rather than giving them straight.
    You did nothing wrong, since the thread started outside the Homework Help section to begin with, I 'm just mentioning it.
  5. khian
    Oct 25, 2011
    6
    R3,R4,R5,R6 are parallel..so assigned them as RX
    RX=[(1/R3)+(1/R4)+(1/R5)+(1/R6)]^(-1)
    RX is series to R2. just add them..
    RX + R2 = RY
    RT = [(1/R1)+(1/RY)]^(-1)
  6. Georacer
    Nov 25, 2009
    5,151
    1,266
    That's good and all, but no one asked to find the equivalent resistance of the circuit. Please keep on topic.
  7. Jon Wilder
    Oct 25, 2011
    23
    Good to know and is actually the way I prefer to do it. Perhaps it would've been better off to answer his question with a question.
    If you want, go ahead and delete my original post (I would've simply edited the original but the board doesn't allow that after a certain time period). Here's a better pic...without the resistors labeled. See if he can tell us which one is R1 and which is R2.
  8. Georacer
    Nov 25, 2009
    5,151
    1,266
    Nah, it's ok. You will be able to edit at your hearts content after you hit your 10th post.
