series parallel circuit
Discussion in 'Homework Help' started by locke3, Jun 3, 2012.
  1. locke3
    Jun 3, 2012
    Hey guys, new to the forum. I have what I think will be an easy question for someone. see attached picture.
    The question is....how do you calculate the voltage drop at R2 and the current though R3? I believe the total current to be .396 A and the total resistance to be 30 ohms. I know the answer for R2 is 3V but when I calculate it I get 6V. Any help would be great!
    Thanks again
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
    Show as your solution first.
  3. locke3
    Jun 3, 2012
    For the voltage drop at R2
    I took the current through the circuit .4 and multiplied it by the resistance in R2 and R3 which was 15Ω. My calculated voltage drop was 6.
  4. Jony130
    Feb 17, 2009
    3,990
    1,115
  5. Ron H
    Apr 14, 2005
    7,050
    657
    Half the current flows through R1.
  6. bountyhunter
    Sep 7, 2009
    2,498
    507
    HINT: erase R1, it's irrelevant to the voltage forced across the right branch.
    Combine the two lower parallel resistors (R2 and R3) into one equivalent. Use that value to set up a voltage divider in the right circuit branch. The voltage across the lower equivalent resistor appears across EACH of the two resistors combined (R2 and R3).... so you can use that voltage to directly calculate the current through each one.
  7. locke3
    Jun 3, 2012
    Thank you guys.....I understand now!!!
