series-parallel circuit help?
Discussion in 'Homework Help' started by DaDead, Jan 21, 2009.
  1. DaDead
    Jan 21, 2009
    i am doing a series-parallel circuit for homework and i am trying to see if i done something wrong? i believe i have because i already get 12v when i add up v1 and the A node. can someone help me? sorry for my handwriting :|
  2. MareBear
    Member
    Oct 29, 2008
    22
    what information is given?
  3. DaDead
    Jan 21, 2009
    12 as the VS R1 is 2k ohms R2 is 1k ohms and the series R 3 + 4 that are combined are 4k ohms
    r1 + r2 ( r3||r4) he said to find the volt and current across the resistors and it already equals 12vs if i add the I1 and node A
  4. mik3
    Feb 4, 2008
    4,846
    63
    Combine R2 and R34 in parallel and use the voltage divider rule to find the voltage across them. Then divide this voltage by the resistance of each one to find the corresponding currents.
  5. DaDead
    Jan 21, 2009
    thank you so much
