Series/Parallel Cap question
Discussion in 'Homework Help' started by sausages, Mar 8, 2007.
  1. sausages
    Mar 8, 2007
    23
    I've just started an electronics course and I've already found this site invaluable in my understanding of electronics in general. I've been assigned a series of questions to complete as part of my year and I'm just wondering if someone could give me a little help.
    These are the diagrams I have been given. I'm asked to "Write the parametric equations for the above network and calculate the values of A, B, C and D parameters, at a frequency of 1kHz, "
    I'm trying to add up the impedances of each component. Obviously the resistors are no problem but I'm having trouble with the cap. I'm just having trouble trying to see if it's in parallel or series with the other resistors. I'm thinking series but I'd just like to be sure before I do the calculations. I'll probably have one or two more q's , hence the big thread :)
    Thanks for any help
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The capacitor will act as a resistor to gouund. Calculate Fc and there you have it.
  3. sausages
    Mar 8, 2007
    23
    So basically treat the cap as just a normal impedance calcu. and proceed.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    That should give you the correct answer,
