Series or Parallel Capacitor
kkazem
Joined Jul 23, 2009
160
Equations for CAPS in series: Ctotal=C1*C2/(C1+C2). For Caps in parallel: Ctotal=C1+C2. Watch out for voltage rating on the caps, especially in series as the applied voltage will be distributed generally unequally if the cap values are unequal. Also, for high-voltage work, you may or may not need a resistor across each cap in series to help equalize the cap voltage on each cap due to unequal leakage currents. Regards, Kamran Kazem, V.P. & CTO, Magnetic Design Labs, Inc.
18,463
Hello..
is there any way to series or parallel these two capacitor value 17nf and 151pf???
thanks
Certainly there is. But now I have a question is what do you want to achieve? What value of capacitance is your goal?? Providing that information will lead to a much more detailed answer, and probably much more useful as well.
