Series DC Circuits worksheet Q 25
Discussion in 'Homework Help' started by Circuits123, Feb 6, 2014.
  1. Circuits123
    Dec 7, 2012
    18
    I'm confused by how you would do the test described in this question. I know you would put one of the probes on the test point. But where do you put the other probe? The instructions say "between each test point and ground," but aren't there 2 grounds in the diagram? (I'm assuming the triangles are the grounds)
  2. shteii01
    Feb 19, 2010
    3,505
    512
    The two grounds are probably connected.
  3. kkazem
    Jul 23, 2009
    160
    28
    Using a triangle for gnd is a way of keeping schematics clean & simple. Unless they have a number next to them like 1, 2, etc, the grounds are meant to be common, connected together. Regards, Kamran Kazem.
