While looking at the web with respect to this problem I found this site:
http://www.electronicsfaq.com/2013/11/measuring-hot-resistance-and-cold.html which produced some baseline data about the cold resistances and hot resistances of some 240 V bulbs.
http://www.analog-innovations.com/ has a spice model for incandescent lamps, which of course can be modified to change the power level. Jim Thompson PE, a frequent contributor in the Science Electronics Design NNTP group designed that model.
I am sure that the question here, intended to use the "hot resistance" of the bulbs, as calculated, but I suspect that once one does the calculations, it will come close to the theoretical, unless of course we wish to disregard KVL and KCL.
Even knowing the lumens per watt at 60, 80, and 100 are between 16 and 17, once the bulbs are in series, I suspect the lumens per watt would be reduced to the values normally associated with the lower powers and not their normal operating lumens per watt, as the "heating" power has been reduced as well.
This brings us back to the lamp consuming the most power in the series string as the one being the brightest. That would be the 60 Watt lamp.
