series circuit. please check my answer. thank you very much.
Discussion in 'Homework Help' started by dizzyuz, May 5, 2008.
  1. dizzyuz
    May 3, 2008
    [​IMG] series circuit. please check my answer. thank you very much.
  2. techroomt
    May 19, 2004
    198
    a) you're right, the resultant angle = 45 deg (pi/4 rad) inductive.
    b) what is the impedance (hypotenuse) with a resistive side of 1000 ohms, and an inductive side of 1000 ohms (2000 ohm Xl - 1000 ohm Xc) @ 45 deg angle? 1000 ohm x 1.414, you're right
    c) to get pure resistance, the reactances must cancel each other, Xl = Xc. this is resonant freq. so set Xl = 2 x pi x F x L equal to Xc = 1/ 2 x pi x F x C and solve for F.
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    Did you intend to remove the problem from viewing by other interested members?
    hgmjr
