series and parallel
Discussion in 'Homework Help' started by Andrewee, Jan 7, 2016.
  1. Andrewee
    Jan 7, 2016
    Hi guys. there is this circuit which combines series and parallel. I was stuck at it because I not sure which to start solving. Parallel or series first?
  2. djsfantasi
    Apr 11, 2010
    2,899
    870
    A picture is worth a thousand words. And help us figure out what you are talking about. If you don't know how to add a picture, check out this blog entry on inserting pictures into your post.
    anhnha likes this.
  3. shteii01
    Feb 19, 2010
    3,496
    511
    Both, but not at the same time.
  4. crutschow
    Mar 14, 2008
    13,462
    3,353
    It rather depends upon the arrangement of the serial and parallel components.
    If there's a lot of parallel components as compared to the serial than it may be less work to do the parallel combination first.
    Conversely if there's more serial components then doing the serial first may work better.
    You rather have to look at the circuit and think about which order of solution requires fewer calculations.
  5. WBahn
    Mar 31, 2012
    18,064
    4,904
    Since we aren't mind readers, we have no idea what "this circuit" looks like. This is like saying that you have a car that needs repair and asking if you should open the hood or trunk first. The question has no meaningful context.
