Serial To Parallel
AlexR
Joined Jan 16, 2008
732
Its not clear to me how your circuit actually connects to the PIC or what part the PIC will play in the scheme of things.
For that matter if you are using a PIC why do you need external shift registers and data latches?
And lastly why are you using a PIC16F84? Its a primitive obsolete chip with very limited functionality. If you used something like a PIC16F627/628 (or for that matter any PIC with a USART) you would have an on-board UART to do your serial input which would simplify you task considerably.
AlexR
Joined Jan 16, 2008
732
Ok, that make sense but I would imagine that the project would be to make a serial to parallel converter using the PIC16F84.
You do not need the external shift register and data latch. The PIC can be programmed to do it all.
There are plenty of tutorials and examples on the WEB, a google on "pic bit banging" brings up lots useful of hits or take a look at the Microchip application note AN555 at http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1824&appnote=en011045
