Serial output from OSC2 pin?
Discussion in 'Embedded Systems and Microcontrollers' started by allcircuit, Mar 21, 2009.
  1. allcircuit
    Thread Starter Active Member
    Jan 7, 2009
    31
    I am using 16F88, due to all the ports B has been use for parallel communication with LCD, I try to use this pin as serial output (Only transmission needed). Can I have basic assembly code for this so that I can further modify it?
    I will appreciate for your help. Thanks
  2. allcircuit
    Jan 7, 2009
    31
    anyone? Wish to get help here
  3. t_n_k
    Mar 6, 2009
    5,448
    783
    Have you read the appropriate section (Chapter 11) in the 16F88 data sheet?
    Also search the Microchip website - there are application notes
    If you have the MPLAB software, there is an application Maestro assembler module for PIC 16 USART included.
  4. thatoneguy
    Feb 19, 2009
    6,357
    718
    I've used an internal oscillator on a 16F627, and the best I could do is flash a heartbeat LED on it. Make sure the config flags are set for INTRC_XXX for which port either is an I/O or clock out.
    You might be able to move another function to that pin, and use the original pin for the serial.
    Another option: Use a shift register for the data lines on the LCD, it frees up a couple pins.
