I am searching a serial driver like that one: http://datasheets.maxim-ic.com/en/ds/MAX6969.pdf
This driver (max6969) is sink driver (current flowing from vcc through the driver to the ground), but i am searching the same one as source that can supply current to the LED.
I tried and didn't found anything... I am sure you will find something.
Thank you.
Thank you.
