Serial data transmitting using Zigbee
Discussion in 'Embedded Systems and Microcontrollers' started by Anurudda, May 12, 2010.
  1. Anurudda
    May 12, 2010
    I am doing a project and going to use zigbee in that project. I want to transmit the data that is coming from serial port of a PC to another equipment that has a serial port. I decided to use to Zigbee to communicate between those two port as i want to do it in wireless. So, how can I do this? can I connect PC's serial port's TX & Rx pins directly to Din(data in) & Dout (data out) pins of Zigbee module? If there is anyone who likes to help me, it would be appreciated.
    Regards,
    Anurudda.
    PS: I am willing to use Zigbee-pro module. If it is wanted, I can give the data-sheet of that module.
  2. retched
    Dec 5, 2009
    5,201
    313
    Yes, you can use the serial port to talk to the zigbee.
    This is basically what you need to build for full fledge control of the zigbee from the PC.
    http://www.cooldrives.com/rstoziwiad.html
    Google RS232 with zigbee to get lots of other ideas.
