I am looking at changing a circuit which needs to trigger a relay when a serial RS232 cable is connected. These need to be low powered as they are battery supplied. There are only TX, RX and GND lines available. I can see 2 avenues:
1. The TX line when not transmitting is about -6V. I was thinking of using this signal to an RC timer through a diode to power the base of a transistor.
2. Currently the circuit uses a MAX221 datasheet which seems to have an auto shutdown when an invalid signal level is detect. There is a -invalid pin on this IC and I'm interested in anyone having experience with this chip and pin?
