Serial Cable Color Code
Discussion in 'The Projects Forum' started by petebear, Feb 27, 2007.
  1. petebear
    Jan 23, 2007
    22
    Anyone know if there's a standard color code for a serial cable (9 pin)? I spliced one open and I've got:
    Purple
    Green
    Orange
    Blue
    Red
    White
    Yellow
    Brown
    Grey
    There's also a bare wire in there. Anyhow I'm looking for ground(5) and DTR(4). I'm thinking it's red and green, but just curious if anyone knew for sure. Any help is appreciated.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The internal wiring color is uncontrolled. You need to go from the connector pins to each wire to correctly identify the function.
    On second look, the colors do seem to go with the pin numbers. Brown should be pin 1, white should be 9, and the others follow standard color code.
  3. petebear
    Jan 23, 2007
    22
    Damn. Okay, thanks anyhow.
