Serial Adder Subtractor
Discussion in 'Homework Help' started by maryrose0911, Jan 29, 2014.
  1. maryrose0911
    Jan 29, 2014
    8
    How will you construct and test a serial adder-subtractor circuit using JK flip-flop and shift registers? Thank you in advance :)
  2. MrChips
    Oct 2, 2009
    12,624
    3,451
    This sounds more like a homework question so I have moved it to the Homework Help forum.
  3. alfacliff
    Dec 13, 2013
    2,449
    428
    you dont say how many bits, or who to control the add / subtract.
    one way is do a serial to paralell conversion, run the paralell trough a 74181 ( one for each 4 bits needed) and back to serial. the 74181 will add subrtract, shift and many other functions.
  4. WBahn
    Mar 31, 2012
    18,085
    4,917
    You need to show YOUR best effort to do YOUR homework. That will allow us to see what your approach is, what you are getting right, and where you are going off the rails. We can then offer suggestions to get you back on the right track.
    The first step is you have to have a clear understanding of what the objective is at a level of detail that will let you draw a timing diagram showing all of the signals and what should happen at each clock pulse.
