sequential switching using time delay relay
roscoeman
Joined Aug 24, 2013
Hi ,
Wonder if anyone can provide me some inputs on a design to switch sequentially one after another three solenoid valves for plant watering in my garden. I cannot switch all the water lines at one go because the water pressure will drop.
ANy help greatly appreciated.
thanks
Wendy
Joined Mar 24, 2008
23,429
The Completed Projects Forum is for Completed Projects only. It is meant to allow members to show plans for projects they built so other members can duplicate them if desired. New threads are also automatically moderated per Moderator review for this reason. Your thread does not belong in this forum, and was moved here.
MaxHeadRoom
Joined Jul 18, 2013
28,702
A quick solution might be to use a Smart Relay, they are made/relabled by a few Manuf. Idec, Siemens, Omron etc.
The programing is either done through the input buttons on board for simple apps or in some cases the S/W is free.
They also have an on board real time clock for time of day functions.
Max.
wayneh
Joined Sep 9, 2010
17,498
Look into lawn watering controllers. Sometimes you can find them very inexpensively (I got one on clearance for less than $5) and they're designed to do exactly what you want.
