Sequential Network Problem-Mealy model
Discussion in 'Homework Help' started by laguna92651, Mar 29, 2008.
  1. laguna92651
    Thread Starter Active Member
    Mar 29, 2008
    101
    I'm constructing a transition table for a synchronous sequential network. It is 2 JK flip flops. I've developed the transition expressions okay, but am not sure of the format to use for the Transition Table. The network reflects a Mealy machine. It has 2 states and 2 inputs.
    I only have 1 example of a Mealy and 1 example of a Moore machine, so I don't have much reference to figure out the methodology or format. Sorry for all the dashes, it was the only way I could get the table to line up.
    This is my current Transition Table, I'm not sure if this correct.
    Present State---------- Next State-------- Output
    (Q1Q2) -------------------(Q+1Q+2) -------------z
    -------------------------------Inputs (xy) ---------Input(x)
    00 01 10 11 ----------0 1
    00 -------------------------01 00 00 00 ----------0 1
    01 -------------------------00 01 00 01 ----------0 1
    10 -------------------------01 10 10 10 ----------1 0
    11 -------------------------00 10 10 10 ----------0 0
    One area I'm confused on is the output, there are 2 inputs, x&y. It is my understanding there should be one output column for every combination of input variables (4 in this case). The z output expression doesn't have a y in it, z = Q1Q'2 + x'Q'1. I assumed I don't need to include y in the output.
    Second question, when I evaluate a Next State expression do I treat it as an OR?
    As an example for x=1 y=0, Q1Q2 = 10
    Q+1 = yQ1 + xQ1Q'2 + xy'Q1 + y'Q1Q'2 + xQ1Q2
    Evaluates to: 01 + 111 + 111 +111 + 110
    Is this like a Or statement, if any one of the terms evaluates to 1, Q+1 = 1?
  2. adrian.dmc
    Feb 22, 2007
    52
    To clear you thoughts the diference between a Moore and Mealy machine is as simple as this: in a Moore machine the output depends on the current state (say the value in the flip-flops) but in a Mealy machine the output depends on the current state AND the current inputs.
    Now the table. I used to draw the transition tables like this:
    ...PS........I........NS.....O
    .Q1 | Q2 | X | Y | Q1+ | Q2+ | Z
    .0. | 0. | 0 | 0 | ... | ... | ...
    ..........| 0 | 1 | ... | ... | ...
    ..........| 1 | 0 | ... | ... | ...
    ..........| 1 | 1 | ... | ... | ...
    .0. | 1. | 0 | 0 | ... | ... | ...
    ...........| 0 | 1 | ... | ... | ...
    .1. | 0. | 0 | 0 | ... | ... | ...
    .1. | 1. | 0 | 0 | ... | ... | ...
    Where:
    PS - present state
    I - inputs
    NS - next state
    O - outputs
    About the output question. There's no need for a y.
    I didin't understand quit well your last question but I'll try to explain what I undestand of it.
    Imagine you have this equations:
    Q1+ = Q1 x + Q2
    Q2+ = Q1 y + Q2' x
    z = Q1 Q2 y
    The next state if (x = y = 1, Q1 = Q2 = 0) will be:
    (using boolean algebra)
    Q1+ = 0 * 1 + 0 = 0
    Q2+ = 0 * 1 + 1 * 1 = 0
    z = 0 * 1 * 1 = 0
    Hope helped...
    EDIT: you were right its hard to make the table to line up.
  3. razzler
    Member
    Feb 9, 2008
    16
    use k maps.it's easier and you get the equations immediately.for the output, you only get a "1" if it satisfies your conditions example if x and y are 0, you get z=1 or when the present state is in this condition, the output is high regardless of the inputs
  4. razzler
    Member
    Feb 9, 2008
    16
    oh i just noticed, your table is lacking the flip-flop input columns. if you have this, it is easier to get the equations needed
  5. laguna92651
    Mar 29, 2008
    101
    On the second answer, why does;
    Q2+ = 0*1 + 1*1 = 0 wouldn't it equal 1?
    If Q1+ evaluated to;
    Q1+ = 1*1*1 + 1*1 + 1*1*1 what would Q1+ equal?
    I'm still going through your first answer, thank you.
