separating circuits series/parallel
Discussion in 'Homework Help' started by phantomvs, Jan 21, 2016.
  1. phantomvs
    Jan 19, 2016
    39
    Ok so here it goes i got this questions that asks me to find the voltage on R4
    It tells me :
    R1=100 ohms
    R2= 1000 ohms
    R3=500 ohms
    R4= 1000 ohms
    R5=500 ohms
    So what i did is find the total resistance of R2 &R5 its 333 ohms
    then added R1 + R3+R4 , So 100+333+1500 = 1933 ohms
    Find the total amps At=0.10 amps
    Then did R1 x At = 1.03 volts
    and so on but i think i screwed up somewhere ?
      File size:
      40.7 KB
      21
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
    Notice that (R3 + R4) are also connected in parallel with R2 & R5.
  3. WBahn
    Mar 31, 2012
    18,087
    4,917
    You need to be more methodical in documenting your work. For instance, you say
    then added R1 + R3+R4 , So 100+333+1500 ...
    R1 = 100 Ω, so that's your first term.
    R3 = 500 Ω, which is no where on the right.
    R4 = 1000 Ω, which is nowhere on the right.
    333 Ω, which is no where on the left.
    What your equation tells me that you are doing is
    100 Ω + 333 Ω + 1500 Ω = R1 + (R2||R5) + (R3 + R4)
    Are R1, (R2||R5), and (R3 + R4) in series? Remember, to be in series, whatever current flows in one MUST flow in each of the others.
  4. phantomvs
    Jan 19, 2016
    39
    Your right, it thought R3 and R4 were in series but its parallel
    So R1 is in series with the rest of the resistors.
    So if i do 1/Rt= 1/R2 + 1/R5 + 1/R3 + 1/R4 = 166 ohms
    Then add in the R1 166 + 100 = 266 ohms
    I/R = 0.075 Amps for I-total ?
  5. WBahn
    Mar 31, 2012
    18,087
    4,917
    But are R2, R3, R4, and R5 all in parallel? Remember, components are in parallel only if the exact same voltage appears across all of them. Is the voltages across each of these four resistors the same?
    You are trying to just throw values at regurgitated formulas without taking the time to think whether or not those formulas apply.
    Take it step by step. Identify two components that are either in series or in parallel. Then combine just those two components and replace them with their equivalent. Then repeat this process until you get down to just a single equivalent component.
  6. phantomvs
    Jan 19, 2016
    39
    I think thats it , i am not seeing the whole picture.
    From what i see, R3 and R4 are in series but parallel to R2 and R5
    That would then be in series with R1 ?
    Its the R3 and R4 that get me the way they are connected.
  7. WBahn
    Mar 31, 2012
    18,087
    4,917
    If R3 has some current flowing in it, must that same current also flow through R4? If so, then they are in series. So replace them with a single resistor, perhaps called R34, that is the series equivalent of R3 and R4. Redraw the circuit with that replacement. Then go from there.
  8. hp1729
    Nov 23, 2015
    2,094
    232
    It might be easier to understand if you redraw the circuit as you go along step by step.
    Figure R2 and R5 in parallel then redraw the circuit with R2||R5 as one resistor.
    Figure R3 and R5 in series then redraw the circuit with R3+R4 as one resistor.
    Then figure these two resistors in parallel.
    Then add R1.
  9. phantomvs
    Jan 19, 2016
    39
    So i redrew it and from what i get , doesn't seem to make sense.
    I drew R1 as 100 ohms and the put R34 in series with 1500ohms and put R25 in parallel at 333 ohms.
    I think i got lost somewhere. Even when i add the R1 with R34.
    I will try to post a pic.
  10. WBahn
    Mar 31, 2012
    18,087
    4,917
    Show us what you did step by step. A schematic is worth a thousand words.
  11. phantomvs
    Jan 19, 2016
    39
    this is what i was thinking, sorry for the cheap pic.
    But what i did is
    R2R5 (333) R34 (1500)
    So 333 x1500 / 333+1500 Gives me 272.50 ohms
    Then i added in R1 at 100 ohms so 372.50 ohms
    At = V/R So 20v / 372.50 = 0.05 Amps Total
    Any of this sound right ??
      File size:
      18.2 KB
      8
  12. WBahn
    Mar 31, 2012
    18,087
    4,917
    Again, take it one step at a time.
    Draw a circuit in which R3 and R4 have been replaced by their series equivalent. It should look something like this example:
    You are trying to do too much at once and it is clear you aren't ready for that yet and that you are making needless mistakes as a result. Don't worry, we were all there at one point and you will quickly move past the need to be so painstakingly careful.
  13. hp1729
    Nov 23, 2015
    2,094
    232
    Sounds good.
  14. WBahn
    Mar 31, 2012
    18,087
    4,917
    This verbal description doesn't come close to your schematic:
  15. hp1729
    Nov 23, 2015
    2,094
    232
  16. phantomvs
    Jan 19, 2016
    39
    Sorry about that pic, i uploaded wrong one.
    I don`t have access to a pic right now, but this is what i did .
    So basically i took R3 and R4 and added them together as its a series circuit.
    Then created 3 parallel circuits . One under another .
    So R2 1000 ohm parallel to R34 1500 Ohms parallel to R5 500 ohms.
    Did the parallel formula and came with 277,77 ohms and added 100 ohms of R1.
    Found the total amperage I equals 20v / 377.77 equals 0.05 amps
    Now i know parallel circuits voltage is the same and series current is the same.
    Original question asks for R4 volts , that is where i am stuck.
    Unless i screwed up somewhere on simplifing the circuits.
    Thanks again for your patience :)
  17. WBahn
    Mar 31, 2012
    18,087
    4,917
    If you could find the current going through R4, could you figure out the voltage across it?
    If so, can you figure out a way to find the current going through R4?
  18. hp1729
    Nov 23, 2015
    2,094
    232
    Finding R4 voltage.
    After you find the total resistance of R2, R3, R4 and R5 consider a simple series circuit made of R1 and R2345. Find the voltage across R2345. Then consider the series circuit of R3 and R4 to find the current through R3 and R4, then the voltage across R4.
  19. phantomvs
    Jan 19, 2016
    39
    This is what i had drew
  20. hp1729
    Nov 23, 2015
    2,094
    232
    Super. 20 V did you say? Total resistance divided into voltage gives you current. Current times R2345 ohms gives you voltage across R2345.
    R2345 voltage divided by R34 voltage give you R34 current,
    R34 current times R4 gives you voltage across R4.
    phantomvs likes this.
