separate positive and negative parts of audio signal
Discussion in 'General Electronics Chat' started by squilliam, Nov 16, 2010.
  1. squilliam
    Apr 6, 2010
    I'm trying to create a simple analogue audio amplifier and need to separate the positive and negative parts of the input signal. Is there a way to do this without introducing distortion for example when using two diodes? I was thinking of using two op amps with either power rail connected to ground but there must be a better way.
  2. AlexR
    Jan 16, 2008
    735
    54
    A google search on "precision rectifier" should get you what you are after.
    squilliam likes this.
