Sentence errors
Discussion in 'Feedback and Suggestions' started by gorgondrak, Dec 29, 2014.
  1. gorgondrak
    Nov 17, 2014
    61
    DIGI book chapter 11 Finite State Machines 11.5
    The second sentence says, "That means that its output is dependent only by its current inputs." It should be, "That means that its output is dependent only on its current inputs."
    The third sentence says, "Previous inputs for that type of circuits have no effect on the output." It should be, "Previous inputs for those types of circuits have no effect on the output."
    In step four it says, "Since we have built a More Finite State Machine...". It should be, "Since we have built a Moore Finite State Machine". Also, in the next sentence it says, "This is the reason the outputs column has two 1...". It should be, "This is the reason the outputs column has two ones...".
