Sensors in my project
Discussion in 'The Projects Forum' started by SakoLB, Feb 22, 2010.
  1. SakoLB
    Nov 11, 2009
    I am working on a project for one of my courses and I need to input the values of temperature, current, voltage and irradiance to a FPGA.
    The problem is that I don't know much about sensors so I'm not sure if there are digital sensors that I can directly use or I should get an analog sensor and convert it in one way or the other.
    I searched the forum and google but it confused me so any help about this subject is appreciated.
  2. Bernard
    Aug 7, 2008
    4,248
    424
    Most sensors are analog, self voltage generating or current passing thru device converted to voltage. The voltage amplified, scaled & converted to digital via analog to digital converter. There should be individual panel meters for specific requirements with external digital outputs.
    SakoLB likes this.
  3. Bernard
    Aug 7, 2008
    4,248
    424
    Check internet for digital panel meters , 'found hundreds.
    SakoLB likes this.
  4. jpanhalt
    Jan 18, 2008
    5,699
    909
    Irradiance might be a bit trickier to measure. What methods have you considered and discarded? Are there specific wavelengths and bands in which you are interested?
    John
    SakoLB likes this.
  5. SakoLB
    Nov 11, 2009
    Thanks guys. I checked your replies now because my partner took the job for the sensors.
