Sensors and LEDS
Discussion in 'The Projects Forum' started by charlottelilyward, May 21, 2013.
  1. charlottelilyward
    May 21, 2013
    I need some advice in relation to a project I am currently doing.
    In the circuit there would be two LEDS, one would be turned on and one off, when movement is sensed the light that was on would turn off and the alternate light would then illuminate. I am having trouble working out how to build this circuit as I am a novice to electronics !
    The sensor would only need to sense a distance within 40cm.
    Any help or advice would be appreciated, and clear simple descriptions would help, as like I said Im a novice!
    Charlotte : )
  2. MrChips
    Oct 2, 2009
    12,635
    3,453
    If this is a school project show us what you have come up with so far.
  3. Dodgydave
    Jun 22, 2012
    5,153
    770
    You can use a ready made PIR sensor, and feed it into a 555 timer circuit.
  4. Bernard
    Aug 7, 2008
    4,240
    414
    I assume that each time motion is detected, the lights reverse. Sounds like a toggle flip-flop is required & light drivers.
  5. c.marsh
    May 16, 2009
    100
    i guess it really depends on your background, if you have experience with writing code i've discovered that using atmel chips (primarily the attiny85) and writing code for it they are amazingly easy to work with.
    I used an arduino to program my chip and i'm working on motion activated lighting for an aquaintance now. what he'll end up with is a small circuit with a chip in the middle, some led's coming off it, a PIR sensor and 2 1.5v coin batteries. all in all VERY small circuit and power source.
    On the other hand, you can go entirely hardware.
