sensored bldc start up failure
Discussion in 'The Projects Forum' started by etiquoe, Oct 23, 2010.
  1. etiquoe
    Jul 11, 2010
    27
    hi,
    i'm working on my bldc motor driver.
    i'm using 3 hall sensors to detect rotor position.
    But sometimes, it doesn't start without hand trigger.
    i don't know what's the problem.
    when it failed to start up, the hall sensors signal is detected, and the microcontroller provide the right sequence control signal, but the power inverter output signal give wrong result.
    help me please...
    enyone?
    :confused:
  2. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    And your schematic is...
  3. etiquoe
    Jul 11, 2010
    27
    this is the schematic of the power inverter.
    High side and low side input signal is provided from microcontroller based on hall sensor states
  4. punisher454
    Member
    Jun 29, 2009
    16
    I'm not positive (still trying to get my 3-phase working) but I think you may need to pre charge the bootstrap caps before they will fire the first time. possibly try to charge the cap for start-up by turning on the low side first.
  5. thatoneguy
    Feb 19, 2009
    6,357
    718
    It seems to be a software issue, but there isn't any source code, and I don't see the hall effect sensors in the schematic.
    I'm guessing port initialization or other startup tasks that may not be completed due to a typo or oversight.
  6. etiquoe
    Jul 11, 2010
    27
    yup, i do charge the cap before begin to start it up
  7. punisher454
    Member
    Jun 29, 2009
    16
    Can you post the code?
  8. etiquoe
    Jul 11, 2010
    27
    i haven't used pwm yet.
    i just try to make the motor rotate in CW and CCW
    this is the code:
  9. punisher454
    Member
    Jun 29, 2009
    16
    I would try to get your pwm working. But first I'd suggest posting your code and schematic over at rcgroups, that seems to be the #1 bldc knowledge base.
    etiquoe likes this.
  10. thatoneguy
    Feb 19, 2009
    6,357
    718
    Took a quick glance, didn't simulate it though.
    From your code
    Code ( (Unknown Language)):
    1.
    2. void first_init (void)
    3. {
    4.     PORT_PHASE = 0b00010101;
    5. }
    6.
    This is called in the main routine. Doesn't this set all the coils to "ON" on the motor, preventing it from turning?
  11. etiquoe
    Jul 11, 2010
    27
    this is to make the bootstrap capacitor charged. as punisher454 mentioned, the bootstrap caps need to be pre-charged first before they work.
  12. etiquoe
    Jul 11, 2010
    27
    i tried to increase the bootstrap caps pre-charge period, from 100 us to 250 us. and the start up problem was solved :D
  13. etiquoe
    Jul 11, 2010
    27
    about the pwm, i haven't got any idea yet about using which one pwm scheme. still need much information about each pwm schemes. i haven't found any source which desribes about the pwm schemes in detail. So, it will be so helpful if you have more information about it :D
  14. punisher454
    Member
    Jun 29, 2009
    16
    Ok I'm no BLDC expert at all, in fact mine wont be working untill I get a parts shipment later this week.
    But, from what I have researched so far it looks like you can get away with just switching the high side fets on/off and applying the PWM signal to the low side only.
    Variable braking can be accomplished by applying a PWM signal to all 3 low side coils at once.
    You can also reduce the current draw and smooth the motor rotation by turning on the next fet in your commutation table BEFORE turning off the current one. You'd probably have to set up a timer to control how much overlap you get. Basically you'd be smoothly transitioning to the next phase rather than abruptly switching.
    And thats about all I know. Glad to see your startup is working better now.
    etiquoe likes this.
  15. etiquoe
    Jul 11, 2010
    27
    ok, i'll try
    thanks..
    :D
