sensor reading problem
Discussion in 'Embedded Systems and Microcontrollers' started by sahar, Oct 23, 2008.
Thread Status:
Not open for further replies.
  1. sahar
    Oct 23, 2008
    hi
    every one
    i'm doing a project to control light intensity within a room at89c51 interfacing with adc0808.i have used 3 light sensors with pin 26,27,28 of adc.this system always send the reading 255 whether sensors are connected or not.i cant understand the problem.plz help me to solve the problem.i follow the code mentioned below.is any problem in my code or i will check my circuit.
    #include<reg51.h>
    void se(unsigned char x);
    void con(unsigned char value);
    void ms(unsigned int value);
    sbit clock=P3^2;
    sbit ALE=P3^6;
    sbit OE=P3^5;
    sbit SC=P3^3;
    sbit EOC=P3^4;
    sbit Addr_A=P1^0;
    sbit Addr_B=P1^1;
    sbit Addr_C=P1^2;
    sbit Relay1=P1^3;
    sbit Relay2=P1^4;
    sbit Relay3=P1^5;
    sbit Relay4=P1^6;
    sbit Relay5=P1^7;
    unsigned char lux;
    unsigned char array[]={'0','1','2','3','4','5','6','7','8','9'};
    void timer0() interrupt 1
    clock=~clock;
    void serial0() interrupt 4
    if(RI==1)
    se('P');
    RI=0;
    lux=SBUF;
    switch(lux)
    case ('a'):
    Relay1=1;
    se('a');
    break;
    case ('A'):
    Relay1=0;
    se('A');
    break;
    case ('b'):
    Relay2=1;
    se('b');
    break;
    case ('B'):
    Relay2=0;
    se('B');
    break;
    case ('c'):
    Relay3=1;
    se('c');
    break;
    case ('C'):
    Relay3=0;
    se('C');
    break;
    case ('d'):
    Relay4=1;
    se('d');
    break;
    case ('D'):
    Relay4=0;
    se('D');
    break;
    case ('e'):
    Relay5=1;
    se('e');
    break;
    case ('E'):
    Relay5=0;
    se('E');
    break;
    default :
    se('N');
    RI=0;
    void main(void)
    unsigned char value;
    P2=0xFF;
    EOC=1;
    ALE=0;
    OE=0;
    SC=0;
    TMOD=0x22;
    TH1=0xFD;
    SCON=0x50;
    EA=1;
    ES=1;
    // IE=0x92;
    TR1=1;
    TI=0;
    RI=0;
    // get data from adc
    while(1)
    //use channel 0
    ms(30000);
    se('X');
    se('O');
    se('P');
    Addr_A=0;
    Addr_B=0;
    Addr_C=0;
    ms(255);
    ALE=1;
    ms(255);
    SC=1;
    ms(255);
    ALE=0;
    SC=0;
    while(EOC==1);
    while(EOC==0);
    OE=1;
    ms(255);
    value=P2;
    OE=0;
    con(value);
    se('X');
    //use channel 1
    ms(30000);
    se('y');
    Addr_A=1;
    Addr_B=0;
    Addr_C=0;
    ms(255);
    ALE=1;
    ms(255);
    SC=1;
    ms(255);
    ALE=0;
    SC=0;
    while(EOC==1);
    while(EOC==0);
    OE=1;
    ms(255);
    value=P2;
    OE=0;
    con(value);
    se('Y');
    //use channel 2
    ms(30000);
    se('z');
    Addr_A=0;
    Addr_B=1;
    Addr_C=0;
    ms(255);
    ALE=1;
    ms(255);
    SC=1;
    ms(255);
    ALE=0;
    SC=0;
    while(EOC==1);
    while(EOC==0);
    OE=1;
    ms(255);
    value=P2;
    OE=0;
    con(value);
    se('Z');
    unsigned int x,y;
    for(x=0;x<value;x++);
    for(y=0;y<1275;y++);
    unsigned char x,d1,d2,d3;
    x=value/10;
    d1=value%10;
    d2=x%10;
    d3=x/10;
    se(array[d3]);
    ms(255);
    se(array[d2]);
    ms(255);
    se(array[d1]);
    ms(255);
    SBUF=x;
    while(TI==0);
    TI=0;
    thanks in advance
Thread Status:
