Well, even if the current is only momentary, you'll still be subjecting the resistors you've been considering to enough power to turn them into light bulbs for a brief moment. You might get away with a momentary load of 3x to 5x of the power rating, but most DIP resistors are rated around 200mW, and 60w is 300x that.
And as I also mentioned, DIP/SIP resistors won't be useable due to the HV, unless you can find some components with a minimum of 0.17" pin spacing and 3.5kV rating. They might be out there, but will likely be pretty scarce.
The HRV37 series are 1/2 W 3.5kV rated, which is actually a bit marginal for the voltage rating. Vishay also makes the HRV68 series which are 1W 10kV rated. I haven't looked for a source, but if you want this STE to be really reliable, those would be a better option.
Connecting the STE to the DUT is another issue. Can the resistors, and preferably the NPN Darlington arrays be integrated into the DUT? If not, you're going to have a connector problem, as you'll need that minimum .17" between pins. Either way, it's going to require a good bit of real estate. Conformal coat will help out a great deal in reducing the footprint, as then you won't have to worry so much about air gaps. However, the working voltage and power ratings will still be a concern.
You mention that the 3kv flash will be brief - exactly how brief?
My concern is the time required for latching the shift registers. The data inputs need to stabilize, then the parallel load/shift needs to go high, and then P/S\ needs to fall to latch in the data. Up until now, I'd made the assumption that the input would remain high until the Stamp pulled the line low. This is obviously no longer the case, so give me some timing info.
