Hi
I am working on a project and i had to blast up an HP printer for some components.
I needed a light type of sensor which it actually reads every time it is crossed.
It seems that is used to read revolutions, a spot is made at a certain point and when it is crossed in the sensor it counts as a revolution.
I found this sensor in the printer but my problem is that i cannot find the part number or datasheet on how to connect it to use in my project.
All i need is to know how to connect it so a datasheet or maybe someone knows how to connect it is enough.
Here with this message there are to pictures of this sensor available. It has 4 pins going out of the sensor.
Please con someone help me figure them out
Thanks in advance.
Thanks in advance.
