sensor for obstacle detection
Discussion in 'The Projects Forum' started by velsegway, Jan 25, 2012.
  1. velsegway
    Jan 24, 2012
    i am doing final year project.
    i need an optimum sensor for detecting obstacles at the range of nearly 4metre.
    which one i go for?
    IR sensor or
    ultrasonic sensor.
  2. PaulEE
    Member
    Dec 23, 2011
    423
    32
    Which do you prefer and why?
  3. BillB3857
    Feb 28, 2009
    2,402
    348
    First, welcome to the forum. You will find a lot of folks from various backgrounds that are more than willing to help. You will find that you get more assistance if you first provide more information about your present understanding of the topic. As an example for your present inquiry, please state your understanding of each type sensor and what you consider to be the strong and weak points of each approach. I'm sure you will get a reasonable amount of discussion.
  4. thatoneguy
    Feb 19, 2009
    6,357
    718
    For that distance, ultrasonic will be more accurate. Most LED ranging systems don't reach past 2 meters accurately, it is a non-linear response (due to less and less light hitting the photo-transistor).
    Ultrasonic is a linear response based on time, and can go very far with good accuracy if the temp, pressure, and humidity are known.
    velsegway likes this.
