Sensor connection to Arduino
Discussion in 'Embedded Systems and Microcontrollers' started by TheChickenMaster, Oct 28, 2008.
  1. TheChickenMaster
    Oct 28, 2008
    Hi everybody!
    I'm a newb in the world of electronic, and i'm working on a robot for a school project. I'm doing well, but i'm facing a basic problem. I got a Arduino Diecimila and three Sharp GP2Y0D340K IR range Sensors, and I wonder how to (physically) connect them together. So, is somebody could give me a tip?
    TheChickenMaster
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    All three sensors can share a common power and ground line. Each must have its own 1 uF capacitor and 1 ohm resistor. And each has to have a separate input line for the distance pulse.
  3. TheChickenMaster
    Oct 28, 2008
    Alright, this is very usefull to know tks. But I was talking about wich kind of wireing should I use, as i said : i'm a beginner in electronic.
    But still thank you man!
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Sorry, but "which kind of wiring" doesn't translate very well. Do you mean solid versus stranded? Any insulated wiring of about 24 ga should work just fine.
    Of course, I have no idea about the application of physical layout of your project.
  5. TheChickenMaster
    Oct 28, 2008
    Sorry, english is not my first language. I mean, How do I convert those five little Pins into a wire that I can plug into my Arduino.
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You can either solder the stuff directly onto the pins (not recommended), or make a printed circuit board to mount the sensors and your choice of connector. The awkward part is the capacitor and resistor each sensor has to have. Nothing in the very poor data document says so, but I would not be surprised to find that both external components need to be close to their sensor.
    Here is a link to a thread that discusses making printed circuit boards - http://forum.allaboutcircuits.com/showthread.php?t=15033.
  7. TheChickenMaster
    Oct 28, 2008
    Thanks man!
  8. John Luciani
    Apr 3, 2007
    477
    For a small number of sensors you may want to mount them on a
    vector board and wire the sensor pins to a connector or test points.
    I have some breadboarding hints at http://tinyurl.com/5foeou
    (* jcl *)
