sensor circuit
Discussion in 'The Projects Forum' started by alwqas, Feb 28, 2014.
  1. alwqas
    May 7, 2012
    hi dears
    I need your help to build a circuit for this project
    a student want to help blind people using sensors
    his idea said : sensor will detect if there any stones or solid body in front of his way
    now : what he need to do this circuit and is the photo sensor is a proper one?
    also I need your help to build the circuit
    regards
  2. pwdixon
    Member
    Oct 11, 2012
    488
    56
    A lot easier and cheaper to use ultrasonic sensors.
  3. mcgyvr
    Oct 15, 2009
    4,787
    973
    stones (if you mean like "rocks") is going to be virtually impossible to detect properly without constant false triggering at any terrain change..
    A decent sized solid body should be fairly simple.. But rocks/stones/pebbles on the ground ain't gonna happen.
    and yes ultrasonic sensors would be the way to go..
  4. Falcon69
    Nov 11, 2013
    19
    This might be too expensive, nor do I know how you could make it work, but what about a 3d laser scanner? You'd probably need a fast processor to make it work. But it could scan everything near and translate that into an object being in front or near the blind person.
