I need to monitor a piece of 3ph equipment and detect (via microcontroller) when the motor is running. I do not need to measure the current - I just need to close an unpowered circuit.
I need to minimize invasiveness on the machinery. I've found plenty of fancy split core current sensing switches but none are inexpensive. In my ignorance, it seems like a loop in one of the hot leads would be enough to use a hall effect sensor or reed switch ... then I could debounce the data programatically and get away for >$5/ea rather than $100+.
Why would this not work? any details in the explanation will be appreciated - I'm pretty ignorant, but trying to learn - Thanks!
