I've had this mic for a while now I've almost never used it (low end) So I decided to fire it up so I could sell it. Nothing, no sound but I'm getting full RF so I knew it was the mic itself so I decided to unscrew the capsule to see what's inside, it's pretty sealed but soon as I removed the capsule I noticed that the wires were just hanging, 2 black and a red one. If I look at the capsule I can see there's 4 blobs of solder so I would assume that those wires were connected there I did a quick test but nothing is happening. Why 3 cables? and 2 black and one red. I could see 1 red 1 black but I don't get the 3rd one I would assume it's negative as well.
Here's the mic
http://www.sennheiserusa.com/newsite/produ...?transid=500594
And some pix
On the above picture on the capsule right underneath the body (bottom right) there's a ^ metal ring with another blob of solder so I would assume that goes to the shorter black cable as the ground.
Here's the mic
And some pix
