hee ! hee ! hee !If you say so... (giggle) perhaps not quite lucky with that statement, but see what you meant to say
My switches does not need power to work.
The little solid SMPS units that keep the standby mode working in modern electronics equipment would not take that sort of supply power cycling for very long before the whole device decided to never turn on again.Then I believe you could set your device to poll the outlet, by briefly applying power to it, for say 10ms every 3 seconds or some such scheme.
As others have said, it's a school project, give the guy a break!
I think a lot of today's devices would not respond well to that kind of power cycling.Limiting the scope is certainly an option for a school project. If your professor agrees, make your smart outlet work for devices that don't need anything but power to turn back on.
Then I believe you could set your device to poll the outlet, by briefly applying power to it, for say 10ms every 3 seconds or some such scheme. The vampire power would be cut by the duty cycle reduction. If an "on" condition is detected by polling the smart outlet could leave the power on. The user would only need to know that a device might require a few seconds to turn on once the switch is thrown.
Actually the 'and such' is where the vast majority of power usage and potential waste is where the big numbers come from.Unfortunately this ignores the bigger target items; TVs, monitors, and such.
by Jerry Twomey
by Aaron Carman
by Aaron Carman
