Sending power to video camera 100ft down the line
Discussion in 'General Electronics Chat' started by RickWilliams86, Jul 13, 2014.
  1. RickWilliams86
    Jul 13, 2014
    I am making a video system where I can control the camcorder down a 100 ft line.
    I have a 100 ft S-video, rca video and power cable running a pan/tile head which works fine, but I have created adapters to extend the 1.7mm X 4.75mm plug/jack to a standard 2.1mm X 5.5mm CCTV camera power connector so I can use the standard cable.
    I have also wired the two remotes to RJ 45 jacks and can run them through 100 ft cat5 cables.
    If I connect the adapters without the 100 ft cord it works, so I know my adapters are wired properly.
    The pan/tilt head has a 12 volt regulated power supply, not sure the full meaning of that.
    So what would be my solution to getting the power to the camcorder?
    Panasonic PV-GS camcorders
    Bescor MP-101 motorized Pand & Tilt Head
  2. Brownout
    Jan 10, 2012
    2,375
    998
    What isn't working?
  3. Dodgydave
    Jun 22, 2012
    5,170
    777
    Send 12v dc down the power cables, or use a local psu at the camera end.
  4. djsfantasi
    Apr 11, 2010
    2,914
    881
    Or send 18vdc (number picked somewhat at random) and locally regulate it to 12vdc.
