Sending data from Stmf103 microcontroller using UART to serial port (using c)
asif45
Joined Nov 12, 2015
15
Hello everyone,
I am quite new to microcontroller so need to know how can i send data from Stmf103 microcontroller using UART to serial port (using c). Is there any library for this that i can use? I will really appreciate your help. Thanks in advance
asif45
Joined Nov 12, 2015
15
Thanks for the reply . I just start learning about this so at 1st i just wanted to send a simple "hello world" using UART from Stmf103rbt6 microprocesssor to a server via wifi. if you give me a head start that would be really helpful.
dannyf
Joined Sep 13, 2015
2,197
First, try to blink an led.
After having done that, check out sample code from St. On my blog page, I had an example of sending data over uart / USB. It utilizes uart1 and is done via interrupt. But can be easily ported to other parts or chips.
asif45
Joined Nov 12, 2015
15
By the way,expected a lot of reading of data sheet and tool manuals.
If you aren't prepared for that, try mbed or arduino stm32.
Hi Danny
Thanks for your reply. I looked the UART example in your blog. It was really helpful. I uploaded a file here, i just want to modify it for sending data over uart . but it's little bit complicated for me. i am using keil uvision. I made some change in Uart config.c but it has error. When you have time can you please take a look what i am doing wrong. thanks
