Show what you are doing in order to send data.
#include"stm8s.h"
#include <iostm8S105c6.h>
#include <intrinsics.h>
//#define cli() __asm("cli")
//#define rim() __asm("sim")
#define PR 0
// Setup Timer 2 to generate an interrupt every 480 clock ticks (30 uS).
char A[64] = "1010101010101010101010101010101010101010101010101010101010101010"; // serial number to send to one wire
//int i ;
void SetupTimer2(char a) //40 us
TIM2_PSCR = 0x00; // Prescaler = 1.
if(a == 'r') //
TIM2_ARRH = 0x04; // Wait for 480.
TIM2_ARRL = 0x38;
else if(a == 'p')
TIM2_ARRH = 0x01; // High byte of 120.
TIM2_ARRL = 0x18;
else if(a == 'b')
TIM2_ARRH = 0x00; // wait for 30us.
TIM2_ARRL = 0x3c;
else if(a == 'c')
TIM2_ARRH = 0x00; // wait for 10us.
TIM2_ARRL = 0x14;
// TIM2_IER_UIE = 1; // Turn on the interrupts.
TIM2_CR1_CEN = 1; // Finally enable the timer.
// Timer 2 Overflow handler.
#pragma vector = TIM2_OVR_UIF_vector
__interrupt void TIM2_UPD_OVF_IRQHandler(void)
TIM2_SR1_UIF = 0; // Reset the interrupt otherwise it will fire again straight away.
TIM1_IER_UIE = 0;
int i_count;
char proc_isr;
#pragma vector = 6
__interrupt void EXTI_PORTB_IRQHandler(void) // B interrupt
//sim();
//__disable_interrupt();
PB_CR2 = 0x00; // disable EXTI_PORTB
if(i_count<1)
SetupTimer2('r'); // delay_us(510);
__enable_interrupt();
__wait_for_interrupt();
PB_ODR_ODR4 = 0;//low -> presence
PB_DDR = 0xff;
SetupTimer2('p');//delay_us(140);
else
if(i_count<9) // receive command from master -> 0xF0 search();
else
if(i_count<73) // go interrupt
if(A[i_count-8] == 0)
//send 0 bit
PB_ODR_ODR4 = 0;//low -> bit
PB_DDR = 0xff;
SetupTimer2('b');//delay us = 60 us
// send 1 bit
PB_ODR_ODR4 = 1;
PB_DDR = 0x00;
else
// send 1 bit
PB_DDR = 0x00;
// send 0 bit
PB_DDR = 0xff;
PB_DDR = 0x00;
SetupTimer2('b');//delay 30us for recv signal.
i_count++;
if(i_count>73)
i_count = 0;
//rim();
PB_CR2 = 0x00;
// Main program loop.
void main()
i_count = 0;
PB_ODR_ODR4 = 1;
PB_DDR = 0x00; // porta D pin 4 input
PB_CR1 = 0xff; // PB4 is pull-up input.
PB_CR2 = 0xff; // PB4 is with interrupt
EXTI_CR1_PBIS = 2; // Interrupt on falling edge.
EXTI_CR2_TLIS = 0; // Falling edge only.
i_count = 0;
while (1)
PB_CR2 = 0xff;
by Jake Hertz
by Jake Hertz
by Duane Benson
by Jake Hertz
