send data of time remaining from PC (using VB) to PIC via serial port
Discussion in 'Embedded Systems and Microcontrollers' started by marcus jamus, Aug 8, 2009.
  1. marcus jamus
    Jun 30, 2009
    Hi there!
    I have a question regarding sending a data from PC to PIC microcontroller (PIC16F877) through serial port.
    There is a VB 6.0 program on the computer, where the user would input how much time he/she wanted to. The code of the said program is made similar to a countdown timer. And then I wanted to send that data to the PIC microcontroller through serial port.
    Is it possible? And how easy or hard would it be?
    Thanks so much for the indispensable help
    Marcus Jamus
  2. nanovate
    Distinguished Member
    May 7, 2007
  3. Gaspode42
    Aug 10, 2009
    If I understand you post correctly you need to do the following:
    1. Have a form with a VB text box that you can enter a time into and clock OK or move to another field 'lost focus'.
    2. On 1 start a timer event.
    3. When timer expires (stop timer) and use the MSCOmm1 control to send some text to the PIC.
    What part are you having a problem with?
