Send a string to an lcd using rs232
Discussion in 'Programmer's Corner' started by MASNSN, May 25, 2012.
  1. MASNSN
    May 17, 2012
    7
    Hi
    I need to send strings messages to an LCD through DB9 connection I want to use ISR interrupt vector to receive data from a computer, I will use an Atmega8 to control that. How can I perform that
    Note: I have already developped and tested lcd library
    Thank you
  2. MrChips
    Oct 2, 2009
    12,623
    3,451
    So what is the problem?
  3. t06afre
    May 11, 2009
    5,939
    1,222
    Since you say DB9 I guess you mean RS232 data transfer method. I am not quite sure what you want to do. But could it be that you want to send strings from the PC to Atmega8 controller, that in turn transfer the latter string to the LCD. On the Atmega8 controller you want the make an ISR that take care of the data from the PC.
    I do not know the Atmega8 controller. But this is a very typical micro controller task. That should be quite doable.
