Semikron(SKKh56/16E
Discussion in 'General Electronics Chat' started by TAKYMOUNIR, Nov 18, 2015.
  1. TAKYMOUNIR
    Thread Starter Active Member
    Jun 23, 2008
    351
  2. sailorjoe
    Member
    Jun 4, 2013
    361
    63
    The data sheet seems to say that you will dissipate about 60 watts for a current of 60 amps RMS. It also says you can dissipate heat through the aluminum base plate. So one solution is to mount the device in an aluminum box using some thermal grease to ensure a good thermal bond between the device and the box as heat sink. Alternatively, and likely better, is to find a heat sink that is physically large enough to hold the device, and mount to that, again using thermal grease. Don't hesitate to call the company and get some advice. You're dealing with enough power to hurt you, so be careful.
