semicondutor
Discussion in 'General Electronics Chat' started by sonu, Dec 12, 2005.
  1. sonu
    Dec 12, 2005
    hi
    my question is how can understand the topic of semicondutor briefy
    first wts i am letion
  2. Firestorm
    Jan 24, 2005
    353
    With Google!
    Sorta a broad topic to understand and isn't a 1 hr. ordeal. Google around, you will find tons of stuff. Then ask questions on what you read. You will get better answers. Thx l8er
    -fire
  3. Brandon
    Dec 14, 2004
    306
    semi-conductors are materials which conduct poorly, but still conduct. As their temperature rises, they conduct better as it causes more electrons to rise into the valence range typically. With normal conductors, i.e. copper, silver, etc, the heat does the opposite.
    semi-conductors are typically made impure when used in components. The impurities give the semi-conductor the potential to generate a conductive channel and this is where the transistor fits in.
  4. gotumal
    Mar 24, 2008
    99
    Wikipedia will be good option!
