semiconductor temperature measurement
Discussion in 'The Projects Forum' started by gary1wang, Mar 7, 2012.
  1. gary1wang
    Sep 18, 2008
    Hi Guys.
    I am using diode connected bipor junciton transistor to measure temperature. The voltage is measured by the microcontroller.
    The temperature is calculated base on T=qΔVbe/(nKln(I1/I2))
    n is emission coefficient or ideality factor
    There is some temperature difference between actual temperature and measured temperature. The difference is getting bigger at 2 degrees. and no difference lower than 2 degrees
    My question is that there is a emisson coefficient on bipor junction transistor. Is this emission coefficent increases with temperterature?
    Is there any material that i can read on the temperature effect on transistor on semiconductor physics?
  2. Blofeld
    Feb 21, 2010
  3. gary1wang
    Sep 18, 2008
    Hi, I Want to know how is going on in side bipolar junction transistor related to base emitter depletion region, base width and base collector reverse depletion region
    Best Regards
