Semiconductor devices in SPICE
Discussion in 'General Electronics Chat' started by GentleRV, Nov 1, 2011.
  1. GentleRV
    Dec 18, 2010
    10
    This I see as part of a Power Mosfet:
    General form: m[name] [drain] [gate] [source] [substrate] [model]
    .model [modelname] [nmos or pmos] ( [parmtr1=x] . . . )
    Example: m1 2 3 0 0 mod1
    m5 5 6 0 0 mod4
    .model mod1 pmos
    .model mod4 nmos ( vto=1 )
    My question is after the m1 are numbers to which those refer?
    is any number fine?
    Please use a real datasheet from a manufacturer to produce a spice model.
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Welcome to AAC!
    I am moving this thread where it is more likely to get attention.
    Have fun!
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    The numbers "2 3 0 0" are nodes. The order of the nodes is important. The names of the nodes are generally not important; but it can be helpful if they are meaningful names.
  4. crutschow
    Mar 14, 2008
    13,529
    3,393
    To perhaps further clarify, the nodes are connection points in the circuit. Thus all nodes of the same number are connected together. In Spice, node 0 is always common (ground).
