I don't know if I am asking some stupid questions but I can't really move without knowing them.
(1) In reverse bias situation electrons attracted towards positive terminal and hole attracted towards negative terminal widen the depletion region .My question is that why can't these hole combined and make a bond with the metal terminal because the negative terminal will give electrons to the p side [as battery always provides electrons].
(2) True or false ?
"The current in forward bias flows because the potential across the diode is more then the barrier potential but the current flows due the potential applied across it ,it is not the diffusion process in the diode which occurs after when the external voltage reduce barrier potential to zero."
I am very confused with very basics .
(2) True or false ?
