semiconductor assignment help
Discussion in 'Physics' started by koolstudent, Apr 24, 2005.
  1. koolstudent
    Apr 24, 2005
    koolstudent@gmail.com
    hi,
    plz help me, i m having gr8 difficulty in finding the asnwers for these question(txt file attached).i have to submit it within a week.
    if someone can tell me related sites for these qustions.
    thanks & regards
    koolstudent.
  2. Firestorm
    Jan 24, 2005
    353
    since this is homework we try not to give specific answers but rather point you in the right direction. Can you specify which porblems you are having trouble with? thx l8er
    -fire
  3. koolstudent
    Apr 24, 2005
    problem is that i explained q12,q13,q17 on the basis of ohmic contact.and the answers were crossed out by sir.i asked one of my class fellow and he said that we dont have to answer w.r.t biasing.i dont get it.how should i answer these questions.Also if anyone can refer me some good sites related to cmos'working.
    Q12)describe the nature of the contact,if a metal of higher work function is attached to an n-type semiconductor of a lower work function.
    Q13)describe the nature of the contact,if a metal of higher work function is attached to an p-type semiconductor of a lower work function.
    Q17)if a metal with low work function is attached to an p-type semiconductor of a high work function.what will be the resultant contact.
