Semi-Permanent Circuit
Discussion in 'The Projects Forum' started by nDever, Jun 8, 2011.
  1. nDever
    Thread Starter Active Member
    Jan 13, 2011
    154
    Hey,
    Suppose I have a temporary prototype i.e. protoboard etc. and I wanted to move to a more "permanent" circuit such as a printed circuit board but I still wanted to keep options available such as changing connections, shorting connections to ground or power etc. Would I use jumpers, shorting blocks and/or ribbon cables or is there a better solution?
  2. kubeek
    Sep 20, 2005
    4,691
    806
    Jumpers is the way to go. Or cutting traces and soldering wires :)
  3. mcgyvr
    Oct 15, 2009
    4,793
    976
    or adding additional holes to the board to allow zero ohm jumper wires to be attached
    or adding additional pins that can be shorted with shorting jumper connectors (like on a hard drive to allow you to select master/slave,etc..
  4. Pencil
    Dec 8, 2009
    271
    38
    Nobody mentioned:
    DIP switches
    PC mount terminal blocks
    PC mount wire connection tabs (think male spade terminals)
    Header pins (can be used in conjunction with jumpers or plugs)
  5. THE_RB
    Feb 11, 2008
    5,435
    1,305
    If you get used to having a hot soldering iron next to you when you work then ALL connections are "semi-permanent". ;)
