Semi controlled rectifiers
Tera-Scale
Joined Jan 1, 2011
164
Below are the formulas for Vmean of three phase and single phase semi controlled rectifiers;
Single Phase semi-controlled;
\(V_{mean}=(\frac{V_{pk}}{\pi})(1+cos\alpha)\)
Three phase semi-controlled;
\(V_{mean}=(\frac{(V_{rms})3\sqrt{3}}{\sqrt{2}\pi})(1+cos\alpha)\)
How can I subtract diode drop (0.7V) and SCR drops (1.2V) separately?
34,407
An SCR is a Silicon Controlled Rectifier. ;)
You just subtract the 1.2V forward drop of each SCR and 0.7V from Vpk for each diode that is in the conducting path.
Tera-Scale
Joined Jan 1, 2011
164
So, obviously this depends on the configuration of the diodes and SCRs. For the configuration attached I can just subtract (0.7V+1.2V) from the Vmean at the end. Therefore it is just simple as that. Attached are the formulas I attempted for a practical situation in my country.
http://dc382.4shared.com/doc/3rwHGL1l/preview004.png
